The Samsung DVD player is several years old but the Viera is what was given to me yesterday. So made an exchange from the Toshiba screen to the Viera unplugging the cables from the old and reinserting them into the Viera. I have used the remote from the Viera to setup the DVD but nothing works.
SOURCE: DVD not playing in colour
I have this same DVD player and I have had problems with it, I then returned it and got another, this one too is having problems. They just are not very good quality.
SOURCE: universal remote code for samsung bluray dvd player
I have a Samsung blu-ray dvd player,non of the codes seem to work with my universal remote.
Help.
SOURCE: My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
SOURCE: how to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
SOURCE: I have a samsung dvd player combo. It's ab out 5
the eye wears out on them. if the eye gets damaged the lens will only read certain movies
Testimonial: "Thank you. I appreciate the input and it souns very logical. This was better information that I got from Samsung's tech."
