Our old dryer vented from the bottom through the floor to the crawlspace (ducted to outside)
Our new dryer (Kenmore by Samsung) has a kit to bottom-vent but no practical instructions on how to install it.
HELP!
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
SOURCE: my dryer is not blowing air out of the vent
The hose is clogged. This is a fire hazzard not to mention it takes forever to dry the clothes right?
Try cleaning out the hose ends first. If the entire pipe is clogged its usually easier to replace the hose than clean it.
Also, if the hose is not aluminized or metal of some kind it is a fire hazzerd and needs replacement anyway.
SOURCE: dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
SOURCE: I have a venting question for a new Whirlpool 9550 steam dryer
The vent must remain the same diameter all the way out. Previously installed vents do not often line up well. To get the dryer closest to the wall the bottom method sounds like the best shot. I would build a frame from 2x6s so you can design it exactly to your purpose. A purchased pedestal will still have some limitations.
eric
