When my Hotpoint Aquaius wf 541washing machine is filling with water at various stages of the wash cycle, water leaks fron the door, the drawer, under the washer and some of the seals.
Possible there is no power switched from the controller unit , You need to use a meter to check the output to the motor or else the timer panel is faulty. Also If there is power and the motor does not spin then it can be fault in the motor or the capacitor or FRICTION on the drive.
Hi, Problems with a washing machine not spinning or not draining are often inter related.. If you are having a problem with your top load washer then check out this tip...
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
