Acer Aspire One  PC Notebook Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock will not keep time comp..is only 4 weeks old plus the touch pad freezes up from time to time
Lee Hodgson
Level 3:
  • Acer Master 4,810 Answers
  • Posted on Aug 28, 2009
Lee Hodgson
Acer Master
Level 3:
Answers
4810
Questions
Helped
1782906
Points
15941
The reason the clock won't keep time and date is because the CMOS battery is dead, this battery inside the laptop keeps the date and time in the BIOS even when the laptop has no power to it.
I recommend you take the laptop back to where you bought it from or call the manufacturer as you are still covered by the warranty.
They will either arrange for the laptop to be sent in or send you to a service center.
It's also a good idea to mention that the touchpad freezes too.
Regards.
5helpful
The item is a technika cr-109ip ipod docking station and clock radio but it has not come with and instruction manual and we cannot figure out how to change the time, the alarm time can change but not the...
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode- the hour digits will now flash
2)set/change the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the hour digit
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. Set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Beeper keeps going off at odd times flashing F1 signal and wol,nt be clearec
Hi dorothymedwa,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
4helpful
HOW TO CHANGE THE TIME ON A Technika CR-109IP
2)set the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the number
4)the minute digit will now flash. set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
18helpful
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
2helpful
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
2helpful
Electric oven does not work
After a power failure, some models will automatically resume their setting once the power is restored. On models with a clock, you must reset the clock. If the oven was in use, you must reset it by
pressing the CLEAR/OFF pad, setting the clock and resetting any cooking function.
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing
functions to work properly. The time of day
cannot be changed during a timed baking
or self-cleaning cycle.
Touch the CLOCK pad twice.
Touch the + or – pads.
If the + or – pads are not touched within
one minute after you touch the CLOCK pad,
the display reverts to the original setting.
If this happens, touch the CLOCK pad and
reenter the time of day.
Touch the START/ON pad until the
time of day shows in the display. This
enters the time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
CLOCK pad. The time of day shows until another
pad is touched.
If you do not have the owner's use and care manual,
go to this website and get a free download
of your manual by clicking on your model #.
Once you have downloaded it, you can print it up.
http://sz0047.ev.mail.comcast.net/zimbra/mail#4
100helpful
5answers
How to set the clock on my sharp carousel microwave
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
3helpful
F 1 code after using Jenn-Aire electric oven
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem.This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
49helpful
19answers
Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
11helpful
Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
