First option :check up your device manager : in control panel>system>device manager>sound video game controllers maybe not install your sound card device.
second option : just add my YM [email protected]. for remoting and check-up your PC.
Interesting, but makes sense that remote starter be disabled if there is a potential engine problem. Basically, if you are remoting starting and there is a (known) problem with the engine, could malfunction and cause a fire or other serious damage to other components.
Sounds like some engineer was thinking correctly by disabling it.
What is the engine code - you can take to an auto parts store like autozone to get them to read it and printout the problem.
From there, should be able to get more direction as to how to solve the problem. Better to fix the underlying problem than risk a serious failure.
i will connect with microsoft netmeeting just dial in your polycom ip adderss to it and it will connect if you have given private ip address to polycom then connect with private ip if given with public then with public ip adress .
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
If you can find old Handspring Visor or Palm III Pda ( usually5-20 dollars in trift stores/pawn shops/used gear shoppes ) there is/was a program for it called "omniremote" ( and perhaps others ) that you could draw the outlay of the particular remote and copy the IR-signals from a working remote, so if you could get those 2 ( one of the 2 PDAs , the program ) and borrow a working remote from someone, you could then record and rescue your remoting ability with the PDA. IT is usually good idea to "capture" any particular remote with this kin of setup before they die or get lost. DId this with my TV remote, and once the TV remote died, I could pull the PDA-omniremote recorded out and contiue using the TV like nothing happened. Just a thought,
