I don't think you can charge via Computer USB.. you need to use the Charger plug that comes with the camera. Plug it up into the wall.. You should charge it overnight, but i know you don't have that kinda time
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
The AC power adapter may charge the battery. Make sure that the poser of the camera is off and then insert the battery before starting.
1. Connect one end of the adapter converter to the end of the AC power adapter. Make sure camera is off.
2. Insert the other end of the adapter converter to the PC/AV terminal on the camera.
3. Insert the other end of the AC power adapter into a wall outlet. The status LED lights green when charging is started and lights off when charging is completed. It lights red when a charging error has occurred.
I had this same problem with my Sanyo. I went on E Bay and purchased a new battery.. It was about 8 dollars and shipped from China. But it worked when I put the new battery in and charged it.
hi the best thing you can do is try ebay for a new battery and if that one charges then you know its the battery and ebay are always very reasonably priced
hiak, I had the same problem with my camera. Try opening the battery cover and pressing down onthe battery while turning on the camera. If the camera turns on you have a poor conection between the battery and the camera.I folded a small piece of paper and put on top of the battery then closed the cover.Its worked like new since.
