Question about Frigidaire Dryers
One of the knobs broke on the front of my frigidaire Model FSG748GFS0. It is the knob that starts the dryer. Where can I buy a new knob?
    Problem Solver:
  • 10 Answers
Order HERE
An appliance store will likely have to order as well
Posted on Aug 29, 2009
6ya staff
SOURCE:
Aytag ensignia dryer model # is MDE7657BYW
Go for item 5 on this diagram. You can buy it off appliancepartspros.com
Parts for Maytag MDE7657BYW Control Panel Parts
Aug 24, 2014 | Maytag Dryers
STARTER KNOB BROKE TOTALLY OFF...JUST FLAT TO THE HOLDER
The start switch will need to be replaced. The control panel will need to be removed to replace the switch.
Apr 19, 2010 | Frigidaire FER231A Electric Dryer
Main Dryer Knob Broke Off
Check the Yellow Pages for a repair shop. Make sure you have model number and serial number BEFORE you contact them.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Please. Please jelp me I was told i needed a
From doing my research this dryer has a "turn to start switch." I don't want to sound wrong or demeaning here but, are you trying to "turn" or "push" the switch via the knob to start the unit?
The model number that crosses is GLER341AS2
Frigidaire.
Mar 04, 2010 | Dryers
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The selector knob on my front loader washer the "gallery" broke off in my hand today. Inside the knob was a large spring & a metal ring. What do I do to fix this?
Just get the model number of your machine and buy a new one, you cannot fix it by trying to assemble again, spring had pressure, it may hurt you if you try to fix it, It is much advisableto replace it with new one
Nov 08, 2009 | Frigidaire ATF6000ES Front Load Washer
The knob you use to turn the dryer on has broke off
have you been able to turn it with some pliers try it and then just get a replacement of ebay
Oct 25, 2009 | Frigidaire GLER341A Electric Dryer
Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
May 21, 2009 | GE Dryers
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
79 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
