Place your remote temperature sensor and the inside unit together for about an hour to see if they both read the same or if there is a large difference in the temperatures.
Dashes on the outside temperature reading may indicate that the inside unit is not receiving a signal from the remote. Change the batteries on the remote or change the location of the inside and/or outside units so that they can receive a strong signal between each other.
Your smartphone temperature may be coming from a location that is not near your home. They are often from a weather service. Where is your local temperature sensor located? Is it in the sun? Is it on the south side of the house, or another location where the sun or an air conditioner or other heat source may affect the accuracy of the reading? Try to locate your outside sensor in a shaded location with plenty of ventilation, and away from heat sources.
SOURCE: Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in. Unfortunately this also messed up the clock's time and date. This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
SOURCE: outside temp does not read new batterys in both
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
SOURCE: ext temp is reading wrong external temps on dash
Sounds like the sensor is playing up, your local dealer should be able to assist.
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
