SOURCE: whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
SOURCE: F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
SOURCE: F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
SOURCE: Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
