Be sure you have power ( voltage) from the power supply to inverter boards. If not suspect power PCB part# 8142132110050 available from Encompass for @ $115.00. if that voltage is present suspect invert PCBs which are part of the panel & is No Longer Available part# 8137751900202.
if inverters are bad you might try to research possible availability by researching individual part # from the boards themselves to see if you can find any availability. possibly from partsandproducts.net. They list about 5369 various numbers
SOURCE: need code for "20" Haier tv model tn201auv for rca guide plus+gem
Hi again,
It would seem that you posted multiple times.
For the manual of an RCA CRK76TA1 remote control, pls click here. It is a pdf file and would require Adobe Acrobat reader.
Offhandamnot sure if an RCA remote would work with a Haier television. Youcouldof course still try: 140 191 0000 10748 0001 002 003 004 005 006085 086223 323 2000.
Just a start, do postback how thingsturned up or should you need additional information. Good luck andThank you for using FixYa.
SOURCE: Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
SOURCE: Orion TV-32082, no picture
try fuse f404 on power board, feeds av and other screen circuits but not sound and tuner
