While watching tv screen will freeze and be black and white while you still hear the show you are watching playing.Also tv will not turn off when it does this you have to unplug tv to turn it off
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
did you tried to look in the darkened room just to ensure if their is a white screen. if you could see a very dark screen like almost no backlight the cause could be the t-con board. you can check also the ballast board for screen back light which need to replaced .
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I would check your video connection. And make sure all cables are secured. It is possible the video cable may be bad. Try it on another TV, if it works, it may be the TV
