Cars & Trucks Logo
L
Linda Dupuis Posted on Jul 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuel filter on 2005 turbo diesel smart car
Connot find fuel filter
Larry Ng
Level 3:
Top Expert:
  • Smart Master 14,561 Answers
  • Posted on Dec 10, 2019
Larry Ng
Smart Master
Level 3:
Top Expert:
Answers
14561
Questions
0
Helped
3272690
Points
66455
Diesel.
the shop manual covers this,
RTM
go to your unstated country and dealer and buy it .
watch out some cars have 3 engine manuals so get the right one if this is the case.
factory service manual is the name FSM.
RTM read the manual.
  • Larry Ng
    Larry Ng Jun 12, 2022
    the smart car is sold i many countries,
    and there are NOT THE SAME CAR (DRIVE LINE)
    SO SERVICE IS NOT THE SAME.
    NO COUNTRY TOLD
    NO SIZE ENGINE TOLD. DISPLACEMENT.
    the dealers off all cards made sell a service manual, that covers all service, that is a fact.
    so buy one.
    most cars have 2 filters for years one in tank and one out of tank
    then newer cars only inside the tank
    the reason is simple safety, if road hazard hit the filter you can get fuel fire.
    so less parts in the fuel line means more safety with less EXPOSED.
    also 3 less steps making the car, $$$savings.
  • Larry Ng
    in the USA the EPA claims the filter causes excess warmer fuel, so moved it to the tank.
    warmer fuel evaporates more is there logic.
    splitting hairs endless them.
    the also ended the return line system
    1 fuel line.
    yes know all these rules I do but only here.
    USA EPA or CARB laws CALIF.
    and the missing filters everyone looks for but is not there, (easy)
    google cars missing filter and read to the end of time......... omg
    all mine are in tank here. 2007 up mostly. USA.
    nobody here posts their country
    then gets wrong answers, do you like wrong answers.???? why?
1 Related Answer
Anonymous
  • 666 Answers
  • Posted on Jun 09, 2010
SOURCE: 96 nissan pu sputters and stalls i changed fuel
fuel pump
SUZUKI SUV Grand Vitara diesel glow light on and there is loss of power
no year told , nor country.
sold all over earth with lots of different engines,
my guess in Europe
1988 to1998.
or
1999 t0 2005
2.0 L RF/RFM I4 turbo-diesel
2.0 L RHW/RHZ I4 turbo-diesel
2005 to 014
1.9 L F9Q I4 turbo-diesel
2015 up
1.6 L D16AA DDiS I4-TD
no telling year, country , and which diesel is here, makes answers
10x more hard. so now I go GENERIC and vague.
  1. bad fuel, now filters are bad. , water in fuel or worse./
  2. clogged air filter.
  3. injectors clogged.
  4. newer diesels, have EFI sensors that can be bad.
  5. injection pump bad or messed with and fails.
  6. engine compression fails. (a test)
  7. tank lift pump bad,
  8. and more but no engine or year told.
Where is the fuel filter located on smart car? Where is the fuel filter on smart car?
Hi, there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I bought it, I also had an issue with the file so the girl replaced it in 30 mins
There is another one one bitmanual, also great content
Or try youtube?
2005 diesel smart car starts then dies after a few seconds. changed pump. fuel filter, pressure sensor, cleaned air intake including turbo. Has good fuel pressure. cleaned injectors, have good spray.
black smoke = excessive fuel = bad injector tips , low injector pressure , turbo not working properly
take the car to an accredited diesel specialist professional for a pump pressure and injector pressure test, injector calibration and tip replacement
Ssangyong musso. 2005 2.9 diesel. turbo. hard to
turbo seal is blown allowing oil into air intake charge-white/blue smoke=oil- black smoke=rich fuel mix-replace turbo-cheers Denny
Hi I have a C5 2005 turbo Diesel that is blowing
Hi Paul
You have a faulty starter motor,Common fault on the c5 starter sounds ok but is drawing too much power,And blows the 20 amp fuse for ecm
How do you prime the diesel when you have changed the fuel filter 2005 rodeo turbo diesel?????
fuel filter assembly is fitted with a prime pump. you can use it to prime the fuel. another way is to loosen each line of the injectors to make lose the trapped air.
I have as 2005 jeep liberty and need to know what all I need to do a complete tune up on this vehicle. My jeep is a turbo diesel engine
plugs, boots, oil,oil filter ,fuel filter,air filter check rest of flid levels an belt or belts good luck
Jag x type 2.0Turbo diesel, 2005
Same problem on mine was a block fuel filter (quite common). About £70 fitted by main dealer. I'd stay away from whoever told you the above and get a second opinion!
M
1helpful
How do you prime the fuellines on a 6.0 turbo
Hi,remove fuel filter fill it this should get ya enough fuel so it will start and continue to pump fuel ,riding system of air and system will be primed,Good luck.
Top Smart Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Smart Expert? Answer questions, earn points and help others
