SOURCE: difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
SOURCE: Strange thigs about YAMAHA TW 125
Hi
I have been working on my carb today,the pipe from the bottom of the carb should just run down by the bottom of the swinging arm,there should be another pipe from the pipe on the left side of the carb just above the fuel intake which also runs down to the swinging arm and connect to nothing.
Cheers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
SOURCE: 2001 yamaha ttr 250, starts, idles ok, bogs at acceleration
Has the bike been stored for any long length of time?
old fuel in the carburetor will turn to a varnish like residue blocking the jets,or possibly water in the carburetor.
Testimonial: "The bike was not stored and was ridden regularly, but it still sounds like it could be the carburetor. Thanks for your insight."
