Oil heaters produce no fumes or flames and feature whisper-quiet operation. Because the oil within the heater never needs to be replaced, oil-filled heaters are maintenance-free. In addition, these types of heaters are compact and portable - allowing you to carry them from room to room. Many also feature carrying handles or a set of casters for easy mobility
some of these types of heaters have a hole with a plug, that allow you to add oil, but few of these are in use today. so this being said it is most likely the heating element is failing to fully heat up the oil. parts may be found, if researched in detail on the net
also be known that the electrical componets are most likely to fail befor the oil evaporates. so look at all overheating controls and so on.
good luck,
Here is a tip that I wrote
that will help you to understand about oil filled radiator
heaters....
Oil
Filled Radiator Heater Leaking
heatman10
i have the same problem but is with the patton oscillating heater pch4199. it was working fine for 3 days and then it stopped working i've done what it said to put it on high and unplug it and wait the 10 mins and nothing.
