Microwave Ovens Logo
Posted on Aug 27, 2009
My Galanz microwave WP800AP20-6 is beeping for no reason, buttons will not work and microwave will not function. When I randomly hold STOP/RESET START/MINUTE PLUS, EXPRESS, and CLOCK buttons sequential in random orders suddenly te number buttons work and sometimes I can enter multiple numbers others only one. At this point the microwave automatically powers on and runs for the amount of time. Puzzled!!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2863
Points
Same problem here. Bought the microwave in 2008 and it started doing this last night. Was able to get it function again by randomly punching buttons. Probably a bad microcontroller, it would probably cost more to replace the controller than the microwave's worth.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3102
Points
Mine was doing the same thing and all I did to fix it was hold down the stop/reset button until it beeped and it worked. Apparently the "LOCK" was on due to that button being held in too long. It still beeps, but it cooks the food,
Anonymous
Level 1:
New Friend:
  • Posted on Jul 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2863
Points
I have similar problem
1helpful
How do i turn off the sound on a Hamilton Beach HB-P90D23AP-T3B microwave
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.)
If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
2answers
My Avanti microwave keeps beeping nonstop.
Hi.
If you've tossed the owner's manual to your microwave, check the manufacturer's website. They will often provide a digital version of the manual as a PDF for more recent models. For an older model, you may need to do some digging, but a great start is to just do a Google search for "[microwave brand and model number] manual."
Once you have the PDF version of the manual, press Ctrl + F on Windows or Command + F on Mac to search the PDF for "mute," "sound" or "beep."
Good luck.
Microwave won't turn on and beeps flashing numbers
Some newer microwave models will not function UNTIL you set the CLOCK Function ... ok
There should be instructions in your microwave MANUAL to tell you how to do this; as it can vary widely between different brands and models.
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
2helpful
4answers
I have the problem of my galanz microwave "beeping" turning off and on automatically.???
Try holding down the stop/reset button until it beeps. If this does not stop it from turning on/off automatically then you may have a loose connection in the wiring between the inverter, magnetron, and/or control board, or one of those components have failed. Because of the lethal voltages used and produced with inverters, I do not recommend that an inexperienced person repair it.
It is not heating up feels like it is in child
Try holding the RESET button in until it doesn't say LOCK anymore, did this by trying to solve another issue I;m having with beeps and 310 code??
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
2answers
Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
1helpful
Frozen Display
It may be that the internal firmware has become corrupt, or there is a fault on the main processor board, or with some other area that is effecting the system processor, and thus the system is not able to function properly.
Call the service rep for your microwave oven and bring it in for an estimate.
Jerry G.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
