Nokia 3110 Cellular Phone Logo
Posted on Aug 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i inserted sim im nokia3110 it sends messages automatically please tell me the solution ?is due to any software
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Aug 27, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
0
Helped
17150
Points
224
All ways turn the phone off before inserting or taking the sim card out
1helpful
Whats the problem of my N500 phone that i cant send messages?
I'm using N500 i can call, but im not able to send Messages it will not sent :( what should I do? please help my guys...
My phone is nokia3110 classic and it is requesting phone restriction code please help. imei: 351963035159502
hi restriction codes is nothing but your mobile is locked to particular network.due to this it
accepts only the particular Sim when ever other network Sim is inserted it shows Sim restricted .there
are many ways to solve this problem we can use software,cable ,codes etc....among them codes are the best .
to get the codes you can visit here wickedunlock
Here they ask the following details before rendering the unlock codes they are
1. Mobile model
2. Country from where you brought the mobile
3. Provider to which the mobile is locked
4. Imei number of the mobile
Finally they will send you the unlock codes .once you entered the code in your
mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim.
Just bought a Nokia Fold 2720 - unlocked. Inserted SIM Card and get message when Texting "Sim Card not ready"
Once you insert a sim card inside the phone. Be patient with it, allow it read the sim card, and settle its software. If you try to send a message when you just insert the sim into a phone, the message you will be getting is 'sim card not ready'.
Please insert the sim back into your phone and wait for about 3 minutes before trying to send a text. That way the sim card would have been ready to perform your operation for you.
Thank you for using fixya
Caseytech
Jul 01, 2011 • Cell Phones
2helpful
Hi there... I am unable to send messages from my samsung monte...tot it was due to sim prob bt when used in otr cel msgs r sent..bt when inserted in samsung monte den hvin an error" unable to send message...
First insert the sim on another mobile and check the Message center number from the Message settings (text message settings), note down the number, now insert the sim onto your handset and go into the message settings then text message and replace the message center number with the one you've noted down, save the changes made and restart your phone, it should work now.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 • Cell Phones
1helpful
Hi im sage i can't receive a txt message but i can send them , plz tell me how to fix this ...
Hi, problems about text messages are related to your Sim card (network), not your Samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the Sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in Vise Versa by inserting another Sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
I hope it helps.
Thanks for using fixya.....
1helpful
I cannot send message using my w9601 sony ericson phone. I tried to insert my sim to other mobile unit and it works. I think the problem is my phone. the message centre # did not change and i free up space...
for sending text messages :
1. call to your network operator customer care
2. request the message center number...
3.note it down
4. go to message settings>message center number
5. insert the number which is noted by you and save it
this solves your messaging problem ...
For insert sim:
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using iPhone solution. This problem is caused by Firmware problem and Hardware problem as well.
OR:
New Software Reinstall in the Phone
Good luck
Im trying to send a text messages but it says i need a severice centre number and i don't know the number
insert another sim, turn on the phone than insert you sim back. you should receive the settings automatically
42helpful
6answers
1helpful
Phone restart automatically
enge cp poh pde khit anung unit
2helpful
3answers
My nokia 6630 turn off and automatically turn on when i send any
try soft reseting your phone software first by presing on *#7780# that worked for me. :)
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
