Televison & Video Logo
Posted on Aug 27, 2009
How to hook up xbox 360 to jvc dlp thru hdmi ports
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
9917
Points
90
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
Hope that helps.
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Tried to conntect my xbox 360 slim to my 46" JVC tv via hdmi cable but it wiill not show up, but the tv does display the ps3, i have tried it with different leads and different ports but still nothing, i...
the settings on the xbox are not in the right mode for your tv. you need to change them projectors are 720p so you would need to change the xbox to this.
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Panasonic 42px60u HDMI ports and HD picture wont work.
Using a box of some kind? try unplugging that and wait then plug back to see if the issue is the box. It will try to reboot.
1helpful
2answers
What is the best way to hook up your hdmi cable?
If you have one of the original Xbox 360's, you will need a special cable from Microsoft which allows for conversion from their proprietary port on the back to HDMI. If you have an HDMI port, you will find it right under the port that you would use were you connecting it with standard RCA or R/G/B cables. In either case, connect the cable, and plug the other end of the cable into the television. Double check that your video output settings are set to HDMI, as well as the audio output settings. (Unless you want audio on a different output, such as sending it to an external set of speakers.)
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
1helpful
Can i connect my xbox to X10 projector
yes it does... and there is available input for HDMI, S-VIDEO,M1-DA, & Composet video.
Can't connect XBOX 360 please help!
How many video ports does it have? You may have to search through video 1, 2, 3, or switch the TV itself to component/HDMI depending, with the remote. Should be with an 'input' button.
My tv has a list with HDMI, SVIDEO, COMPONENT, PC, ect. and its a 1080p one, im just assuming all HDTV's have a list
Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
2answers
Xbox 360
Hi there
As far as I'm aware the only way to get hd with the older boxes that don't have hdmi socket is through component unfortunately.
Microsoft have indeed pulled a fast one with this and cunningly released the elite for more profit.
I think the only difference betwen component and hdmi is that hdmi has built in audio in one wire where as with component you require seperate audio.
In short, No. HD only via component.
Hope this is of help
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
