Check here. Results are usually good.
Sewing Parts Online
SOURCE: I have a Necchi supernova Julia 534
sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
SOURCE: Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
SOURCE: I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
SOURCE: Need belt for necchi supernova automatica sewing
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
SOURCE: New belt for Necchi Lelia 513-
Hi. I hear such wonderful things about these Italian-made Necchi! Here are a couple of places you should be able to find your belt:
http://www.sewingpartsonline.com/sewing-machine-belts.aspx
Guy Baker at http://www.sewingmachineparts.net/ always seems to have (or be able to get) just about anything.
http://www.sew4less.com/category/43/Belts_Motor_and_Timing
and, finally: http://sewing-machine-parts-store.com/list.asp?subcat=Belts
Hope this helps!
Happy Sewing!
Robbie
