A single-arm shower faucet in master bathroom (model Kohler K-T15621-4)supplies only cold water although hot water runs in both sinks.
Could this be fixed without calling plumber?
Any ideas?
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
its a single handle kohler faucet in the shower. No hot water is coming out.
Water cold during shower
Water cold
