My problem is exactly the same as the original poster's.
I am able to transfer images to my computer, but when I try to turn the camera on when it's not connected to my laptop, the screen comes on for a second or two, lens comes out, green light is on and then blinks and turns red and blinks and then lens goes back in and camera turns off. I've tried removing the battery, wiping it off, putting it back in, camera also wont charge. It's never gotten wet or been exposed to extreme heat.
Re: My problem is exactly the same as the original...
It may be that there is a setting in the camera that has been changed to make the camera only operate from the computer. I suggest looking around the menu in the camera when it is attached to your computer.
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are
saved by default to the camera's internal memory, which holds different
amounts of images based on how many megapixels are built into the
internal memory and what image quality and compression are selected in
the camera's menu. Once a memory\picture card is inserted in the camera,
the camera then saves the photos to the memory\picture card and ignores
the internal memory.
There are two ways to transfer the images from the internal memory.
To transfer photos to a computer from the internal memory using the
USB cable, first remove the memory card from the camera. Then, when the
camera is connected, the computer and software will only see what is in
the internal memory and transfer those photos or videos. During the
transfer process, the computer makes copies of the photos and videos-the
original images remain in the internal memory. After the transfer is
complete and the camera is safely disconnected from the computer, the
contents of the internal memory can be deleted by using the MEMORY
FORMAT function in the SETUP menu in the camera's menus.
The other way to transfer photos from the internal memory is to
transfer them to the memory\picture card using the BACKUP function in
the SETUP menu. If there is no memory\picture card in the camera, the
BACKUP function is grayed-out. During BACKUP, copies of the images are
transferred to the memory\picture card-the original images remain in the
internal memory. After the BACKUP is complete, the internal memory can
be cleared by removing the memory\picture card and formatting the
internal memory using the MEMORY FORMAT function in the SETUP menu in
the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
My solution is to unistall your current canon software that holds 15 canon components in your computer. You will find them under system task and select remove programs. After you have uninstalled the program, reinstall your "Canon Digital Camera Disk" and follow their prompts. Now you should be able to transfer images again as per normal. I have answered this question in detail under another question postered by "whitecar631" under canon "save folder not found" canon sd1100. This worked for me, but I don"t know how to prevent it happening again. I do know the day I lost all "my pictures", I had previously deleted a large file in my documents. I also experienced "save folder not found" when I tried to transfer images from my canon ixus 100. I was lucky enough that I had all of my original SD Flash Media Cards, so could transfer all my photos again. I have since put all my photos into labelled folders instead of dates and images. Hope this helps, it appears to be a problem in the canon program. Joyce
I would like to know the Operating System of your computer to provide the exact steps on transferring the images from the Camcorder to the Computer. However, I can provide the common information on transferring the images.
Before connecting the Camera to the Computer, set the USB Connect option in the Camera to PTP/MTP from the Main Settings 2 Menu.
Please click on the link below for the information on trasnferring the images to different Operating Systems. Select the correct OS for the exact information.
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files. I suggest that you transfer the images from the Camera to the computer and check if it works. After transferring the images, get the Memory formatted from the Camera and start capturing new images. The edited images will not get displayed in the Camera again. Please try not to edit the images in the Computer without transferring it.
Do you want the pictures transferred to your memory card? that depends on the option available on the camera, try inserting the memory card. select a picture then check options if you can move it to a memory card. if not, download it to a computer and transfer it to the memory card folder.
Have you checked the HP hep site?
Here is their suggestion
Introduction
This document explains how to transfer images from the camera to a computer running Windows XP operating system by using a universal serial bus (USB) cable.
Transferring the images
Follow the steps below to transfer images from the camera to a Windows XP computer.
Step one: Connect the camera to the computer
Turn off the camera.
The camera came with a special USB cable for connecting the camera to a computer. Connect the large end of that USB cable to the computer.
Figure 1: Connect the USB cable
Open the rubber door on the side of the camera and connect the small end of the USB cable to the USB connector on the camera.
Step two: Transfer the images
Choose one of the following methods to transfer the image files:
Method one: Transfer images with the HP Photosmart software
If images on the camera are selected for printing or selected for HP Instant Share destinations, make sure the computer is connected to a printer and the Internet.
Turn on the camera. The HP Import Photos software starts on your computer. If you have set the software to automatically transfer the images in the camera, the images automatically transfer to the computer.
Otherwise, in the Transfer images from Camera/Card screen, click Start Transfer . The images are transferred to the computer, and then if there are any still images that were previously selected for HP Instant Share destinations, those actions are started.
When the Image Action Summary screen appears on the computer, you can disconnect the camera from the computer.
Method two: Transfer images without the HP Photosmart software
If you do not, or cannot, install HP Photosmart Software on your computer, you can still transfer images from the camera to the computer using the Picture Transfer Protocol (PTP) in Windows XP.
Follow the steps below to transfer images.
Turn on the camera.
Windows will automatically launch a program to transfer the images.
When the images have finished transferring, disconnect the camera from the computer.
If you encounter problems, check that the camera USB Configuration in the Setup Menu is set to Digital Camera .
While in Live View , press the Live View/Playback button, and then press the Menu/OK button.
Scroll to the Setup Menu using the left/right arrow buttons.
Use the up/down arrow buttons to scroll through the Setup Menu to highlight the USB option.
Use the left/right arrow buttons to change the setting to Digital Camera and then press the Menu/OK button.
To exit from the Setup Menu , press the Live View/Playback button.
You should be able to transfer the images directly to your computer without transfering them to you memory stick duo. Have you tried connecting the camera to your computer and retrieving the images? If you would rather have the images on your camera on your memory stick duo, then remove the memory stick duo connect the camera to your computer, copy the images off of the camera, turn the camera off, put the memory stick duo back into the camera, plug the camera back in, then transfer the images that you just transfered from the cybershot to your computer back to the camera. They should copy directly to the memory stick duo.
