SOURCE: My 1986 Honda Accord LXi's dash light, PGM-FI
ok is agood idea, but what if it still comes on so you better contact electrician before you do that.thak you
SOURCE: 1986 Honda accord pgm-fi light
Hi
Please check the bellow link to diagnose your problem…
http://www.yesimauto.com/auto-makes/03986_honda_accord_lxi_beside_pgmfi_table_lamp257.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
SOURCE: 1986 accord lxi when idle the rpm gose up and
you need to replace the iac motor the idle air control motor
SOURCE: my 1986 honda accord lxi is giving me a code 13
Code 13 Barametric pressure sensor. ECM uses it for fuel mixture and timing.It is a wht 3-pin harness connector Baro-sensor is located under dash on passenger side make sure if there is a hose that it is attatch other than that you need this sensor
Testimonial: " Thank you Cansmo it was my Barometric pressure sensor had to go to salvage yard to look for that sensor got lucky and found 3 of them thank you again"
