ASUS PSCH-L Motherboard Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on Aug 26, 2009
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422937
Points
3751
From the Asus spec site: Memory Memory Type Please identify RAM upgrade options for Asus - dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 Please identify RAM upgrade options for Asus - dtrquestion.gifax Supported RAM
dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
ASUS k8v mx RAM upgrade
go here http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-MX&os=&hashedid=dJ2XP7zr8tzeYbLp
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
I upgrade old machins and give them away for charity. I have two P3B-F motherboard machines that I have upgraded to 1G, They will not boot up nor will they even run to the point I can enter setup. One...
Make sure the RAM is good, and google it to see if the motherboard supports it. Also, make sure the slots are clean and the RAM sticks are also clean. You may even clean the pins of the sticks using a cotton cloth and alcohol. Sometimes dust and fingerprints on the contacts can cause the RAM not to be recognized by the motherboard. As I remember, the BX motherboards are quite old so probably the RAM slots are full of dust, and you'll need to clean them up either with a vacuum cleaner or a brush of some kind.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Asus S101 How to install additional RAM
Try this link at the bottom of it there is another link to You Tube about the Ram, fingers crossed it helps you out.
If it does please give Thumbs up thank you..
http://www.ultimate-netbook.co.uk/Asus/Asus-Eee-PC-S101/Asus-Eee-PC-S101-Memory-Upgrades/Asus-Eee-PC-S101-2-GB-667-Memory-RAM-Upgrade___279.htm
1helpful
Ram Upgrade
Yes, you can increase the RAM of your Asus X53L, but first, please review/check the product manual of your laptop on what type & maximum capacity of RAM will its motherboard can support & compatible. Any Brand of RAM will do as long as your laptop motherboard is compatible wih & can support its capacity, this is being made to ensure best operations performance of PC. regards
1helpful
2answers
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
ASUS P5L-VM 1394 mother
Here is a link to a website that identifies the specs for your motherboard, and also identifies the type of processors that are compatible with your motherboard. It is Intel Core 2 duo/ Intel Core 2 duo Extreme capable.
It looks like you have a good candidate for a gaming pc, in my opinion. I would suggest that you upgrade the memory to its max of 4 GB. This link also has a list of all compatible memory modules for your motherboard, If you click on a memory module, there is an option on the next page to tell you where you can buy it and for how much.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=32522&mfr=ASUS%2FASmobile&model=P5L&root=&LinkBack=&Sys=32522-ASUS%2FASmobile-P5L-VM+1394+Motherboard&distributor=0&submit1=Search
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Asus psch-l motherboard problem
Recheck data cable for wear & power cable for a possible short. If possible use another power connector within the system.
5helpful
4answers
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
