Necchi 535 FA
SOURCE: how to thread my 535fa
I don't even know where to start. Send me you're email address and I'll get back to you with my phone number as I don't want to post it for the world to see. I'll be able to talk you through it.
SOURCE: Necchi Model 535 FA
Hi! The motor pulley may be worn and cant turn properly causing the motor to be forced so much. The result will be an instant overheating that results to belt burn too. You will need to replace the motor, pulley and the belt now to make it running. Hope this helps and have a good one!
SOURCE: I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
SOURCE: The machine isn't making stitches.
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
