Wont go away
This is a solution that I've found online. It seems to work out for proper removal of the program.
"go to C:Program FilesBlue Coat K9 Web Protectionclick once on license
then press delete button
go to http://www.k9webprotection.com/download/k9-webprotection.exe
then press run
press next
click i agree
click next
go to http://www1.k9webprotection.com/getk9/index.php
fill the form in
then check your email if you've got the license
then copy and paste the license into the installation
click next
then create your own password
then click next
click install
then it has the part where it says error opening file for writing.....
you click ignore
then go to manually reboot later
go to start
go to all programs
go to where it says blue coat k9 web protection
go to uninstall
click yes
then type the password that you made before
then reboot now
and voila...you uninstalled it"
Problem not clear. Can you explain, so we can help you?
Download "Revo uninstaller" from www.download.com. Run program, pick level 4 when prompted, don't worry about backup, click agree to everything and let Revo take care of it. This program is great because it tells the program you want gone to uninstall and if it refuse or gives it a problem, Revo goes through your drive and hunts down every scrap of the program and deletes it all. It even makes a restore point on your drive in case there is a problem so you can restore back to where you started.
this is an ambiguous question. More information is needed.
