Question about Smeg Ovens
Door switch wiring on a smeg se 708x - Smeg Ovens
SMeg duco4ss wiring diagram
Request a wiring diagram for model duco4ss directly from Smeg.
May 13, 2018 | Smeg Ovens
Will these doors interchange, on these models
doubt it but measure both and see if they are close
Apr 21, 2015 | Smeg Ovens
Smeg SE250XUK only oven light works, no fan no heat please help
door switch defective,,try to open close again & again
Feb 12, 2015 | Smeg Ovens
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
How to reset SE 108 x
Customer Service
Here are three things to try. First, on page 64 of the following manual link below, it discusses how to delete the data to the timer clock before turning off the oven. More about programming the clock precedes that but it looks like something you could try. Secondly, I have to wonder what would happen if you just unplugged the stove and left it unplugged for maybe a half hour. Maybe it would magically reset the function of concern. Lastly, you might consult the SMEG techarea below. If that gives no satisfaction, you may have to consult a SMEG technician. Here is a google link to the manual I was examining followed by the smeg tech webpage link which you can register for to use:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiQp8_spt3VAhWGQiYKHZCyD9cQFgguMAE&url=http%3A%2F%2Fwww.smeg.co.nz%2F%3D%3DihtNy8jZPYfrOmUNPKkD9A%3D%3D%2FUSERS%2520MANUAL.pdf&usg=AFQjCNErxuPY_fiXPK7Aop9YNSPCpA6PZA
SMEG TechArea for registered users:
www.smegtech.com
Aug 17, 2017 | Stoves Ovens
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
87 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
Marvin
Marvin
Paul Bade
Are you a Smeg Oven Expert? Answer questions, earn points and help others
