Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
Posted on Aug 26, 2009
Just received a replacement/new uniden phone TCX 905 but it fails to register with our base. We are following directions in manual. Repeated process a number of times.
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Sep 07, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
Helped
20563
Points
50
MAKE SURE THAT INSIDE THE HANDSET THE MODEL TCX905 SHOWS, IF IT SHOWS A DIFFERENT MODEL IT WILL NOT WORK.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
4840
Points
8
Make sure your base does not still have the old phone registered to it. If it does, you will need to remove the old phone from its connection and ensure that you have a minimum of one free space to connect the new phone. If your base unit is a TRU9465 this can be done with the information below:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
This is supposedly all it takes to reset the phone.
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
3helpful
How do I register my Uniden handset? It keeps saying it tis searching and then out of range even though I have it on the cradle
Which Uniden phone do you have? Some should register with the handset in the base unit cradle for 30 seconds to a minute. Others need to be within a few feet of the base but not in the base charging.
For the models that need to be registered with a multiple step process, first make sure that the handset is fully charged; this could take 15 hours. (Make sure the battery is properly connected; if it is loose, the registration may fail. If the battery may have been sitting in a warehouse for months, you may want fresh batteries even for a new phone.) Make sure that the base is plugged in (power and telephone line). I like to check the phone line with a basic corded phone for dial tone if there are any issues with a cordless phone. With some Uniden phones, a registration problem can be cleared up by disconnecting the battery and then reconnecting it before attempting to register the handset. (Make sure that you do not have more registered handsets than the base can deal with. You may need to deregister all of the handsets and start over. Make sure that the handset is compatible with the base.)
The rest of the process requires you to have the handset close to the base and be relatively quick. (You need to tell the handset to get the registration information from the base and the base to send the information before they time out). For the D1688, at the base, you need to press Menu and go to the Register Accy submenu. Press Select. Then press and hold # on the handset you need to register until you see Registering Handset. Wait for the Registration Complete (or Failed) message.
For the DECT1060, the procedure starts at the handset. Press Menu and navigate to Add. Settings. Press Menu/OK and navigate to Register and press Menu/OK. Select the base number and press Menu/OK. Then press and hold the Find HS button on the base for 3+ seconds until the unit enters registering mode. Now on the handset, you need to enter a PIN that matches the one set for the base. (The default is 0000.)
If you still have problems with registering the handset, then it's likely that the transmitter or the receiver for either the base or the handset may have a problem sending and receiving the codes that synch the base and the handset. Most Uniden phones are not meant to be user serviced for this type of proble. You will need to contact Uniden if the phone is under warranty or decide if you want to replace or repair the phone through Uniden's support.
The manuals for all Uniden DECT 6.0 phones are available as PDFs from Uniden. See http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl for a list of all models or search for your specific model. On the manuals pages, the models are listed in numerical and alphabetical order.
I hope this helps.
2helpful
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
I have uniden model TCX 905. I don't have the manual anymore, Where should I look for it on line? I need to change the message on the answering machine and have general information about answering machine....
You can download and print the instruction manual for TCX-905 in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
2helpful
2answers
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
1helpful
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
1helpful
Uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
2helpful
7answers
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
