Defrost timer, defrost thermostat or most likely defrost heater is bad. Turn off refrigerator overnight to defrost this should be done immediately as your refrig. Fan is going to burn up if not already. There are many sites on Internet that tells how to find problem and repair such as repairclinic.com .
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
SOURCE: Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
SOURCE: FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
SOURCE: Hi I have a 1 year old Whirlpool french door
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself.
Defrost thermostat
http://www.fixya.com/support/r10513592-test_defrost_thermostat
http://www.fixya.com/support/r10513650-replace_defrost_thermostat
defrost heater
http://www.fixya.com/support/r10523771-test_defrost_heater
http://www.fixya.com/support/r10523754-replace_defrost_heater
defrost timer
http://www.fixya.com/support/r10523722-test_defrost_timer
http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped.
All the best
Elect_Comp
Testimonial: "Thanks so much! I will try these steps as soon as I get home. Is it worth it to do it myself or is it something inexpensive to have fixed? "
