SOURCE: Need to find a power/battery charger board for Acer Ferrari 4000.
Hi there.
You will be able to get the laptop powerboard from ebay or Sony themselves, although if you get from Sony it will be considerably more expensive.
Good luck and thanks for choosing FixYa!!
SOURCE: dead battery on tahoe 2005 - now no power to ignition
Remove a battery terminal for 5 min. This will allow the computer to reset. Resecure the cable and try to start.
SOURCE: no charge minn kota mk110p marine battery charger
does anybody fix minn kota 3 bank chargers
SOURCE: battery will not charge, first
A bad voltage regulator could cause the problem. Assuming the alternator is working correctly. Jump the vehicle with the battery disconnected and then disconnect the jumper cables. If the vehicle dies your voltage regulator or Alternator are bad, some vehicle have separate regulators from the alternator, if it continues to run the alternator is good but the voltage regulator is probably the cause.
SOURCE: 2005 Crest pontoon boat with
Hi.
You have a short somewhere in the ignition wires. It should not be difficult to troubleshoot, but you will probably need to replace the ignition cylinder.
From what I understood, problem is likely restricted to remote control, the motor shoud be OK (good thing).
To find short (or eventually broken contacts), you need to get a multimeter (eg one here). Set the multimeter on Impedance(Ohms). With multimeter on Ohms test the ignition and the wiring harness. Check if there is contact between different wires, and if wires that should not be connected have continuity.
If there is contact between two points of a wire or between different wires, impedance reads zero Ohms or very low (circuit closed-continuity). If there is no contact, it reads infinity, same as on air (circuit open-no continuity).
If you do not find anything, that means that the short happens occasionally with vibration, in that case replacing the whole wiring harness is advisable.
Before proceeding check remote controls (or motor if concerned) documentation, find the support number and give them a call to check warranty status. Sometimes manufacturer gives more than one year on parts.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
