Question about Kenmore Freezers
Does my upright kenmore freezer model 970-254291 have a 9 volt battery?
    Top Expert:
  • Kenmore Master
  • 64,791 Answers
NEVER HAS AND NEVER WILL
Posted on Jul 10, 2019
Testimonial: "okay thanks freezer keeps beeping and thought i needed to replace battery"
6ya staff
SOURCE:
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Posted on Aug 31, 2009
Anonymous
  • 20 Answers
SOURCE: Need replacement lock-Kenmore Upright freezer, model 1068254983
call sears 800 parts
Posted on Mar 24, 2009
Curt Downs
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
geoff hunter
  • 4793 Answers
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Posted on Feb 11, 2010
SOURCE: where can I get a freezer door key for Kenmore upright freezer model 39153
Locksmith.....just take the model number and serial number to them. If they can't, most likely have to be from the manufacture.
Posted on Oct 07, 2015
My kenmore upright freezer won't stop beeping and everything is still frozen ???
hey.. look for a 9 volt battery. its for the memory and power failures .. so it needs to be replaced ..
Oct 19, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Where is the 9-volt battery located?
Welcome to FixYa.
The 9vdc battery should be just below the door on the right hand side, ( from facing the front ) some models have it behind the toe panel/grill in said location...lower r/h.
That should answer your question. Thanks for choosing FixYa.
Please take a moment to rate the info provided here today.
regards,
macamrkus :)
Aug 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Where do I install a 9 volt battery?
much better to call technician to install that if you confusing to install then observe it next time you can do it on your self
Mar 18, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Door gasket for Kenmore upright freezer model 2539239712
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
74 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
