I lost the battery cap of my K1000 on vacation...I replaced the battery and taped it snugly in place with a bandaid. It hasn't budged in a year! Just find a good strong tape and tape over the battery.
Question edited for clarity. All questions need full 'make model (what it is)'. I took a wild guess from 'K1000'. :>D
Question moved from Firearm Optics, to Make Model category.
there are three different possibilities. remove three screws, take off bottom cover. remove three screws of battery holder, lift to see if the battery wire has corroded or broken off. solve by extending wire and resoldering. the next involves removing the top cover to see if the meter coil is dead,if this is the case it needs to be replaced, or there is a broken lead somewhere. usually it is cause no. 1.
If the focus ring is not working then there is serious damage inside the lens. This cannot be repaired easily and must be taken in for repair.
As for the light meter, this is slightly more worrying as it is damage inside the body. It could be something as simple as the battery contact. But it could also be somehting more serious.
I would recommend taking it for repair.
If repair turns out to be too expensive I suggest you have a look on ebay. Pentax cameras are available with a wide range of prices and so are compatible lenses. A good upgrade would be a Pentax MX or even an LX if you can afford it. The ME super is also an excellent model if you want soemthing simpler.
Clean the battery cap and contacts with a pencil eraser including the cap threads.
there are no new parts available for this model Pentax, so a good used part repair could be expensive.
An inexpensive hand held light meter might be the way to go if the cleaning did not work, and the camera is otherwise working good.
clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
There is a spring in the way. straighten a paper clip and from the top of the camera push it out of the way while you gently push the shaft up. rotating the shaft helps.
or you could file a little of the shaft collar on an angle ( if it's not there ) then rotate the shaft while gently pushing up. don't bend the spring.
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
