I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
I have a Model #3510 Lasko Cyclone Fan and the blades are so dirty. I have no idea how to take this apart to clean them. Any help will be greatly appreciated. Thank you. [email protected] Marjorie Baldwin
There are screws hidden between the slats on the side of the fan that are not obvious. You will also need to pry the fan apart as it snaps together. On the back by the power cord is a round tab over it. There are some screws under it. They hold the motor to the back assembly. It took about 7 minutes for us to get it apart today because of the screws being hidden on the sides. After a cleaning it won't turn on now.
Bex,
THose usually just pull off. You will have to pull hard because there is a spring clamp that they sometimes put around the inside hub of the fan. If there is a clamp, you will need to transfer that to the new blade. Hope this helps!
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
first of all unplug while cleaning on .on the sides it should snap together r have clips on it pull apart r lift the snap hindges on hold the blade with 1 hand turn the knob with other clockwise i think wash r take a dust broom to it put back 2 gether
You can blow the whole fan clean with compressed air or a compressor. It does not require removing the cover. The cover comes off with a twist and a pull, but does not stay on well afterwards, so I don't recommend removal.
Farmerbear at FixYa.com
Joey Temal is right. After removing any small metal retaining clips (which are obvious and easily removed), you have to pull down ridiculously hard to get the fan blade off. Alternate short jerky pulls with steady downward traction.
