Lakewood HV 18-c Floor / Box Fan Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the lakewood fan have a fuse that can be replaced?
Josh Peck
Level 2:
  • Expert 91 Answers
  • Posted on Aug 26, 2009
Josh Peck
Expert
Level 2:
Answers
91
Questions
0
Helped
25368
Points
239
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Mike Jones
Level 2:
Habit-Forming:
Scholar:
  • Expert 106 Answers
  • Posted on Jul 16, 2015
Mike Jones
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
106
Questions
0
Helped
37723
Points
381
This repair is for a Lakewood model HP - 21/SPC.
If the fan will not turn or even hums when you turn the fan.
1. Unplug and Remove the 5/16 inch screws that hold on the front cage.
2. Try turning the fan blades by hand if they are hard to turn and most likely it's lubrication problem
3. Use WD-40 you have two oil holes one of the back one in the front at the top spray WD-40 into the little holes and rotate the fan manually by hand. You'll notice the fan will start to loosen up and turn more freely. We may need to spray and turn it especially in the back oil hole you need to lubricate the entire brass bushing.
4. After you have the motor turning freely reinstall the screws to the front cage and turn the fan on do not run the fan without reinstalling the front cage.
I hope this solves your problem and saves you money on buying a new fan motor or just throwing the fan away.
LAKEWOOD FAN, MODLE MC42, 47" X 44", 104 LBS, 3 BLADES AIR KING, INDUSTRIAL GRADE Fan. I need a fan blade, where to buy please?
Question edited for a lot more clarity.
Question moved from Saws to a better Lakewood Category.
Try these people
https://www.industrialfansdirect.com/pages/replacement-parts
If you have blades, you could get someone to 3D Print 3 new blades for you.
https://www.google.com/search?q=lakewood+mc42
Where can i get a lakewood fan motor for lakewood fan model number HV-18
you would have to go to a place that sells motors and get one by motor type, that than the appliance make and model. All electric motors are standard by size, voltage, speed and fixings.
https://www.google.com/search?q=lakewood+hv+18+replacement+parts
Trying to find replacement electric cord for Lakewood mc 24 lg drum fan
The Lakewood fan uses a computer power supply type female plug.
This is known as a C13 plug: three rectangular female outlets in a triangular pattern.
You should be able to find this type of plug at a good electronics store;
Fry's Electronics would be a good choice.
It may not come in the 10 foot length of the original, but that is what extension cords are for. :)
4helpful
3answers
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
2helpful
Need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
No power getting to my Lakewood fan...
Maybe you tripped over it so hard you de soldered the wires form the inside. Have you openned it? Try it out if you didn't. Check the power cord and follow it all the way into the motor (with the motor openned). Check if one or both cables on the inside are desoldered.
3answers
My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Top Lakewood Dryers Experts
Jay Finke
Jay Finke
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
