Question about Audiovox Car Audio & Video
Advent ADV35 dvd player disk wouldn't eject, now won't load
Advent ADV35 built in dvd player
The disk was stuck in the player and would not load or eject. I was able to eject the DVD and use a pair of tweezers to help it out of the player (the disk was right on the edge of the slot). Now it won't load another disk in the player - any suggestions, maybe a reset feature??
Any help would be great, we are military and about to leave to drive from CA to FL for a transfer!!
  • Anonymous Aug 25, 2009
    Thanks for the solution, since it is built into the car, do you unscrew the unit and unplug it from there and how do you check to see if the eye is scratched? Thanks for the help, oh and it should be an interesting move with a 3 year old! We are praying for a safe - uneventful trip!
  • Anonymous Mar 24, 2014
    Can't load a dvd. Takes the disc in most of the way and says "loading", but then ejects dvd
  • 3,051 Answers
Hello there:
I would first check to see if eye is not scratched or dirty and clean it if nesassary..
If you unplug the unit for a few minutes it should reset it's self.ok
and good luck on the drive i am a retired navy vet and know what you are going thru with the move.
best regards michael
(USN RETIRED)
Posted on Aug 25, 2009
Testimonial: "Thanks!"
  • Michael Thomas
    Michael Thomas Aug 27, 2009
    Hello there again:
    if you can get it uncrewed and remove the unit this will help you get a good look at the eye you might have to remove the top cover if you cant see it with the tray open. ok ?
    ps if you go to the manufactures web site there is a technical support section there if you have or need further assistance from them ok?
6ya staff
SOURCE:
Overhead car dvd player will play but will not eject the cd
Had the same problem and two audio repair techs told me that it was a matter of 'wear and tear' and would be more economical to replace the unit. Wasn't in a position to do that so modified a pair of tweezers by gluing rubber pads on the heads and gently pulled the disc out. Not the best work-through but it sufficed until I sold the car. The cushioned tweezers didn't damage the discs.
Apr 18, 2014 | Farenheit DVD-13 Car DVD Player
ADVENT ADV-35 wiring diagram
I need a wiring schematic for advent adv35 overhead 10' dvd player
Sep 19, 2013 | Pioneer Car Audio & Video
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
My advent dvd player in my Yukon lets me load the dvd says loading then it automatically ejects it! How can I reset the dvd player?
my dvd player will not let me load a cd -- can "force: it in - takes it almost all the way then ejects it
Nov 01, 2010 | Audiovox VOD102 Car DVD Player
Lg dvd rw is not reading when a dvd disk is put in do i need lg dvd drivers for that disk is just ejected out all the time ...i am using windows7 (intel core2duo e4500 processor)
Windows loads a generic IDE/SATA driver to all disk players. If its ejecting then u most likely have a bad DVD ROM. I have built many many pc's using LG Roms and never once needed a factory driver running Windows.
Aug 13, 2010 | LG Computers & Internet
I have a Advent ADV35 mobile DVD player. When placing DVD in unit, it starts to load then rejects and will not play.
while the power is still on find the reset butoon (usally behind faceplate) once found push and hold reset button aprox 10sec (make sure you do this with something that is non metallic) see if that helps hope it does
Jul 24, 2009 | Car Audio & Video
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Advent DVD player in car won't eject DVD
Get hemastats or a thin pair of tweezers and have at it.
Mar 12, 2009 | Sony MV-900SDS Car DVD Player
Car Audio & Video Logo
3,241 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Ekse
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
