Garden Logo
Anonymous Posted on Aug 25, 2009
How to replace drive belt craftsman tractor
What is the best way to replace the drive belt on a craftsman tractor?
In particular, looks like I'll need to remove the mowing deck first - true??
Model # is 917.255450
Anonymous
Level 3:
President:
  • Master 1,776 Answers
  • Posted on Aug 25, 2009
Anonymous
Master
Level 3:
President:
Answers
1776
Questions
0
Helped
646336
Points
6310
There is a video on YouTube that may help you somewhat with the belt replacement. You may want to check it out. Here is the link. Sure hope this helps and best wishes.
http://www.youtube.com/results?search_query=lawn+mower+belt+replacement&search_type=&aq=1&oq=lawn+mower+be
Testimonial: "Good, quick feedback - thanks --"
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Craftsman schematic
Go online to Sears/Craftsman , or go to Youtube ,they will have videos explaining how to
1helpful
2answers
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 • Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
The mower can not go up a hill. It does not quit running just doesn't move.
The drive belt is too loose...you need to replace or tighten the belt...replacement is probably the best option...
heatman101
Replacing broken drive belt.
look under foot rest on tractor usually there is a diagram under there for belt routing and also sometimes on the mower deck it's self
1helpful
Sears Craftsman lawn mower, 46'' deck, m#917273041 - need route for drive belt replacement
There is usually a sticker showing the drive belt route underneath the tractor right by the belts! If yours is missing I 'll try to take a pick of my tractors belt and upload it!
Need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
The belt does not stay on my craftsman ys4500 lawn tractor with a 54" deck
Although the belt may still look good, it is most likely stretched. The cure is to replace the belt.
Best regards, --W/D--
Top Garden Experts
Jay Finke
Jay Finke
john h
