Question about GE Kitchen Ranges
I have a ge monogram zv850s b3ss range hood that suddenly quit working. Lights,fan,display all out. Took filter off. No blinking display light. Chkd power in and I have power. Ohms tested fuse, ok.
Read manual. Troubleshooted to pcb and removed. I have it in my hand and want to further check before spending $450 to replace. Are there any further bench testing I can do before replacing board?
6ya staff
SOURCE:
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: GE Monogram ZV750SY Kitchen Hood
http://www.appliance-parts-warehouse.com
first examine part #166 and related parts for visible damage.
If the circuit board is burned out, then the above website is a suggestion for ordering.
Posted on Jun 14, 2008
Anonymous
  • 132 Answers
SOURCE: 2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Posted on Jul 30, 2008
Anonymous
  • 20 Answers
SOURCE: NUMBER PLATE LIGHTS NOT WORKING
take the bulb back out and clean inside the bulb holder, there may be some corrosion or other debris in there
Posted on Nov 28, 2008
Anonymous
  • 261 Answers
SOURCE: Heater Fan/Blower does not work.
what you need is a blower motor resistot
Posted on Dec 04, 2008
SOURCE: Tail lights don't work on 1998 Chevy Silverado.
check the wiring from the tailights back to the fuse panel, it sounds like an open connection. if i recall correctly check under the dash on the drivers side near the fuse panel for a bunch of wires in a bundle and look carefully for a wire or two that are cut/shorted/or seperated, you can also check under the drivers side kick panel by the hood release.
Posted on Feb 17, 2009
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
My hood keeps blowing the fuses for the rear lights.
There is a short in the wiring to the lights... probabbly a wire rubbed through...
Use an "OHM" meter to find the problem...
heatman101
Jan 12, 2011 | GE Monogram ZV1050SFSS 42" Island Chimney...
Ge monogram hood has power but not working
I have the same problem, only worse. The fuse is in the stack above the motor. You have to remove the vent decorative cover (that stainless tube that goes to the ceiling) and the fuse is in the low voltage circuit close to or inside the gray box that looks like a transformer (on the left). Mine blew out and I replaced the fuse, which lasted for about two months. I replaced it again and it lasted two days. Then, I replaced the triac with an NTE5679 (over on the right) (replaces ECG5679) about two years ago, and the fuse lasted until today. I do not know what to do now. We did not touch a switch just before the fuse blew. The fan was not running, but the lights were on. I think I will try a slightly larger fuse, but first I may look at replacing the fuse with a breaker that I can install behind the filters, instead of removing the stack cover every time the circuit goes out. Good Luck to you.
Ravenhaven
Apr 12, 2009 | GE ZV750SY Kitchen Hood
My range stop working
Hi 7764,
I'm Harvey the Master Plumber.
Your problem is: You have monogram (df 8 08989 9) hood it all of a sudden stop working , there is power (120v) coming in ' but nothing works
If you have the testing equipment and the ability then check the fuse then the transformer then simply follow the power till you see where it stops. Or yu might try utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | GE ZV850SBSS Kitchen Hood
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Diana, the tech sheet I have states that if the unit has a power interruption, reset the house circuit breaker to the hood, if made before 2001. If after 2001, serial number beginning with DA press the start button to reset the hood. Let me know if it worked, Catriver..post back.
Mar 10, 2007 | GE ZV750SY Kitchen Hood
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
