I have a microwave with a broken turntable motor (output shaft broke off.) I found another GE microwave in a trash pile and salvaged its turn table motor out of it. Before I put the motor in my microwave, however, I need to know if the parts are compatible.
The original motor had these specs: AC21V 50/60Hz 2.5/3 r.p.m. 3W P/N 6549W15017A
The salvaged motor has these specs: AC 120V 60Hz 6 r.p.m 2.8W P/N 6549W1S013A
Obviously, I don't want to use a motor that has a significantly different rated power input, as this could result in potentially dangerous electrical problems. The AC21V 3W vs. AC 120V 2.8 W has me concerned.
I assume AC21V is short for AC210V? As in, it uses regular wall voltage? I don't understand how such similar parts could differ so strongly in voltage.
Is 2.8W significantly different enough from 3W that this could pose a concern?
If they are physically alike use it,the units are both120 volt units,you cant operate a 210 volt motor on 120 volts w/o an inverter furthermore it would be 220 volts for that type of motor,its just a production run #
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable. Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
turntable problem? it's probably the motor itself. it's easily removed under the bottom panel. you'll need the pricey ge orig. part; as they use a odd 21volt motor. good luck.
The part you need is the turntable support. Sears shows the part on their parts site, and here's another source that I use. The support just slides onto the motor shaft through the hole in the bottom of the oven.
Some microwaves have a button on the control panel that disables the turntable. Make sure that this button hasn't been pressed.
Next most likely causes are a the stirring (turntable) motor has malfunctioned or possibly a turntable belt is broken or slipping (if equipped). This will involve opening up your microwave (and probably removing it from the wall), diagnosing the problem, ordering the parts, then replacing them.
Remember, while
you can do some repairs on your microwave, what you don't know can kill you...
even on an unplugged microwave, so make sure you understand the dangers and how
to reduce them before you try anything inside a microwave. If you want to
do more yourself, let me know and I will point you in the direction of some
good resources.
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. You may also consider replacing the turntable shaft if it shows signs of wear.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Hi the shaft should just pull up, to remove the motor you will need to turn the oven onto it side, you will see a cover at the bottom of the machine to remove this you will probably need to cut through three of the tabs, you can then gain access to the two screws securing the motor.
When replacing the cover turn it over and fix using the spare self tapping screw to be found in the base near to the cover you just removed.
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
Be certain you are pressing a cook function rather than a timer function.
If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
JVM1850BD002 is a correct model number. This is a GE made by Samsung.
It sounds like the motor or coupler is bad. More likely the motor.
If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor.
If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself.
The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf
(copy & paste whole URL)
Here is the GE part price info on these two parts:
DESCRIPTION DRAWING PART NO. PRICE
MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00
COUPLER 40 WB06X10144 $8.75
If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com
They often have parts for far less than the expensive GE parts.
