I've got a Necchi 535FA. My problem is that the needle goes up and down, but the bottom thread in the bobbin doesn't catch on the top thread. So basically, the machine looks like it's sewing, but it's not because the top string isn't looped under the bottom string--the stitches just pull out. Will this be a difficult fix? The machine is pretty old... should I just give up and buy a new one?
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
My machine made a whirring sound when I was trying to sew. To do patchwork, I was sewing on a part of a seam that was too thick so I had to move the needle to a less dense part. As well, I experienced te problem when I was threading the machine the wrong way.
I have the same problem with my nicchi 535fa and yes the needle is in correctly and the machine is threaded correctly. I follow the instructions and still the needle will not catch the bobbin thread. Also, the needle is not going up and down when I press on the pedal, the machine makes a whirring sound.
