Question about Fuji FinePix E900 Zoom Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
My fujifilm E900 has been working perfectly since we got it but in the last couple of weeks the shutter is sticking it wont open or close properly without manual assistance which still doesnt even open it properly it is effecting the photographs, they are now coming out all dark and hazy even when the camera would normally take a fab pic, any ideas on how to fix this?!
  • 244 Answers
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Posted on Aug 25, 2009
6ya staff
SOURCE:
Has the shutter broke? I have had and used this
remove bottom cover and check for one or more loose or missing ground screws on the bottom board (under the tripod mount plate). If it is missing, you can usually find it sticking to one of the motors
Sep 03, 2013 | Canon EOS 7D Digital Camera
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Fuji E900
Try the video function.
If this works fine then it is most probably the shutter sticking.
To confirm the shutter is sticking turn the camera on, put the zoom to full optical and turn it to face you so you can see into the lens. Watch the inner part of the lens when you take a picture. You should see the shutter fire across the lens. Lines on pictures or over exposed pictures are caused by gaps in the shutter or the shutter failing to fire altogether.
Moisture residue on the shutter leafs is the common cause for this problem.
Some people on here have their own views about what causes lines on photo's. Someone even said digital cameras do not have a shutter and problems were due to software issues....
I have dealt with 100's of different models, including Fuji's E900 and always have found moisture residue to be the cause.
Dec 11, 2009 | Fuji FinePix E900 Zoom Digital Camera
Fujifilm e900 shuts down when shutter is pressed
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Fujitsu Cameras
Canon SD1000 shows black screen when trying to take a picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
My pictures look like I took a picture of a TV
Lines on your pictures are due to the shutter not closing completely. The video should work fine indicating there is no problem with the sensor. Shutter needs cleaning, inspecting for obstruction
Jun 28, 2009 | Fuji FinePix E900 Zoom Digital Camera
Fujifilm E900 camera zoom does not function!
If the shutter and Zoom function both do not operate, you need to send the camera to an authorised repair center. Was the camerra exposed to salt/sea air? If so, you can take a soft rag and gently wipe around the lens area where it meets the body, remove the battery, reinstall the battery and try it. If not, send it in.
Mar 20, 2009 | Fuji FinePix E900 Zoom Digital Camera
FinePix E900 battery problem
The support desk at Fujifilm got me to insert new batteries (rechargables) and try again. The batteries did not die but in the viewer, the picture is very bright (white) and has close horizonal lines running across the picturere. They want me to send it in by registered post (cost to me), only give a quote after inspecting it - which is far enough, but if I don't go ahead with the repairs, it will cost me $40 to get the camera back (as if it would be any good to me). Their web site states that the average repair is about $120, but it could be lots more. When I paid nearly $700 for the thing I expected it to last more than just over a year.
I rang several camera repairers who all told me that the only place that can repapir Fujifilm is Fuji themselves. This is not good and I won't be buying another Fujifilm again.
Apr 08, 2008 | Fuji FinePix E900 Zoom Digital Camera
E900 dropped in drink
Ok, you can open it. BUT PLEASE BE CAUTIOUS AND VERY CAREFUL !! here is a website that explains how-to open the phone and there is pictures. read carefully and go step by step !! good luck. http://www.geocities.com/samsunge900mods/hardware.html
Jul 16, 2007 | Samsung SGH-E900 Cellular Phone
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Feb 15, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix E900 Zoom Digital Camera Logo
396 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
