RCA tv has a "snow sound" but the picture is perfect. I have cable thru a box. Also when playing dvd's, picture & sound are perfect. HELP!!
Thanks, Tami
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
you need to connect using rca leads , the tv should have at least 2 rca inputs . it is not possible to see 2 pictures if you are using rca leads. it seems to me you are using rf outputs or have used rca and joined them with a joiner which will cause the problem
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well.. Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
in order to listen and watch your magnavox
DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to
Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other
..pls remember,Always reverse connected ) (audio will come thru
Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on magnavox **
you need to connect "Audio Output " as can either be : RCA jacks or
"Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has
different type of Audio out jacks ) ** to "iRCA nput or "Optic Cable input" of your magnavox (whichever you want ,based on the necessary cables on your hand ) There you go..Tv/Cable box video and sound are both on the magnavox for recording..
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Sounds like you have a tuner or an antenna problem. If you are using a DVT converter box to watch off the air TV, the signal has to be very good to get sound and picture. Try connecting a VCR or a DVD player trough the coax cable and see if it you get sound an pic on Channel 3 or 4. If you do, it is an antenna problem.
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
