SOURCE: I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Testimonial: "Thanks i will try."
SOURCE: i need wiring diagram for boat 1993 Bayliner jazz
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
SOURCE: i have a yamaha 2
On the tachometer back you have secured a wire thread just like the one from the brakes of a bicycle. The other end of the wire is secure to the engine. This wire complete, need to be replaced. As a test first disconnect it from the tachometer and see if ok if not then the problem is with tachometer.
SOURCE: 2001 polaris sportsman 90 is
It's a two stroke, it has a separate spot to put the two cycle oil under the seat. It injects the oil itself, so you just make sure its always has two cycle oil in there and fill the gas tank with straight gas.
