Hardware & Accessories Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace batteries in the ST01 series timer
Mark
Level 3:
President:
  • Master 704 Answers
  • Posted on Aug 25, 2009
Mark
Master
Level 3:
President:
Answers
704
Questions
0
Helped
592431
Points
2820
The Intermatic ST01 uses a CR2 3 Volt-DC battery to operate the "click-clack" ON - OFF function of the timer.
In order to change the battery, simply pull down the flap just below small display screen. This is the manual switch that you can push to turn the timer on and off.
Just use your fingernail at the top of the door flap and pull down, it will open up and reveal another small tab. This is the battery holder/tray.
To open this, either use your fingernail or a small flat bladed screwdriver at the top to slide out the battery holder tray.
If you remjove and replace the battery within 30 seconds or less, you won't have to reprogram the time/day/date/year. Otherwise taking longer you'll have to reset the time and date feature of the timer.
Don't worry, the timer remembers your program ON - OFF cycles regardless of whether the battery is in the timer or not.
Hope you find this Very Helpful and best regards!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11770
Points
I just discovered that Intermatic is recalling the ST01 timer. Below is the intro to an article (and the URL for the rest) from Consumeraffairs.com. You might want to check into this.
Mark
July 1, 2009
Intermatic Inc. is recalling about 240,000 in-wall electronic timers, models ST01 and EI600. When consumers try to replace the timer’s battery place a metal object through the battery tray slot, the object can reach internal metal contacts, posing a shock hazard to consumers.
http://www.consumeraffairs.com/recalls04/2009/wall_timer.html
Read more: http://www.consumeraffairs.com/recalls04/2009/wall_timer.html#ixzz0Tfqzw8BQ
1 Related Answer
A
Anonymous
  • Posted on Apr 03, 2011
SOURCE: how do you access battery location? ST01 timer
Open following link for ST01C battery, programming, wiring, instructions and manual.
http://waterheatertimer.org/ST01C-program.html#battery
The timer display is blank even after plugging in to charge it. Also pressed reset and that did nothing
Change battery? Applies to Ei600, ST01, EJ500
http://waterheatertimer.org/Programmable.html#st01
Timer has gone bad, timer not rated for freezing temperatures, timer and load do not match
Troubleshoot timers:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I can't even set the time! When I push the clock button I can advance the minutes, but then when I push the hour button the display goes off. Same thing happens if I start with changing the day of the...
If timer is not functioning... the battery needs to be changed or installed (if timer has battery, such as ST01, Ei500, EJ500 timers)
Or timer such as Aube or Honeywell or battery-operated timer mentioned above, or other possible timers not mentioned, has been exposed to freezing temperatures, and is not rated for low temperatures.
Or timer is defective.
Gene
WHERE IS THE BATTERY ON A ST01 TIMER?
Battery compartment is located below the buttons:
Use CR2 battery. Do not expose to freezing temps or battery fails within 20 days.
Timer has 1 year warranty.
Ofter, timer needs to be reset after battery change
Gene
1helpful
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
Gene
When hitting the next/on/off button, it dims the lights vice turning them off???
The EJ500 is rated for incandescent (resistive) bulbs only, and not LED CFL etc.
Max distance between light and timer is 100 feet and wire cannot be underground.
Replace with ST01 timer, or Ei600 timer... these timers are rated for any load (resistive or inductive), and are programmable or dawn-dusk... 7 day... single-pole or 3-way
Gene
Can Woods model 59007 be used in house without
http://waterheatertimer.org/How-to-wire-timers.html
Ground wire is not essential, but neutral wire is
yes the red wire has to be connected to black wire that goes to load
If all you have are two black wires, then use battery operated timer like ST01 or Ei600
Gene
I am unable to set the auto on and off
If reset does not restore functionality, then timer is bad, or in case of ST01 timer, the CR2 battery may need to be replaced.
1) Timer model and brand are unknown.
Copy following link for ST01 timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Add a comment and describe timer in detail, and add if this is new installation or older timer that stopped working.
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
