I have that problem when I use mine in a very dusty environment. Once you take the head apart, clean it out, and reassemble with some air tool oil as lube it should work properly. When you take the head apart be careful for the two small bearings that act as detentes for reverse or forward. They also wear and can cause problems. I keep spare bearings to put in when I open them up.
Make sure your tank is pressurized before using, Also, ratchets have an air adjustment knob that you can adjust how much pressure and power the ratchet puts out. Make sure you oil ratchet before each use with air tool oil
Turn off the engine and place the transmission in park (automatic) or first gear (manual). Engage the parking brake and open the hood. Disconnect the negative cable from the battery terminal using the battery terminal wrench.
Remove the serpentine belt by inserting the end of the serpentine belt tool into the square hole on the belt tensioner and rotating the removal tool clockwise. Unplug the alternator's electrical connector. Remove the bolt holding the positive voltage cable to the alternator using a 3/8-inch ratchet and a metric socket. Remove the positive voltage cable from the alternator.
Remove the alternator bracket bolts using a metric socket connected to a 3/8-inch ratchet. Remove the alternator from the car. Place the new alternator in the mounting brackets and reinstall the mounting bolts using a 3/8-inch ratchet connected to a metric socket.
Reinstall the positive voltage cable on the alternator and tighten the retaining nut using a 3/8-inch ratchet and a metric socket. Plug in the alternator's electrical connector. Compress the serpentine belt tensioner using the serpentine belt tool. Reinstall the serpentine belt according to the belt-routing diagram located under the hood.
Reconnect the negative cable to the battery using the battery terminal wrench. Start the engine and verify that the alternator works.
