SOURCE: model 01902 2350 psi . engine runs fine , sprays
It sounds as if the non return valve in the elbow is the wrong way around .The o-ring normally goes in first then the ball then the spring. Try it and good luck.
SOURCE: How are the valve plates seated on an 8 gallon
the velves are called "reed velves" look from under the head at the velve block as if you were the piston, as the piston gos down it pulls (open)the inlet velve (but the out let velve is held closed by spring presher) and on the way up it (pushes closed on the inlet velve) and pushes the out let velve open so air can be pushed into the air tank,,,has this helped you? they are held in place by light spring presher and maybe fasend by a bolt?
SOURCE: where can I find a Ball isolating valve for a
Ferroli Limted is you best bet phone number 00448715592920
SOURCE: Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
SOURCE: mastercraft air compressor parts
just get some ptfe tape from and plumbing shop and wrap the plug
Testimonial: "tried that, nope! Lasts for about 2 seconds then... there she blows!"
