SOURCE: Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
SOURCE: Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
SOURCE: condensation
The camera has a sensor inside to detect condensation. Condensation can cause the tape to stick the the transport mechanism, resulting in possible damage.
Condensation can occur if the camera is moved from a cold environment to a warm one. The only thing you can do is open the tape compartment, remove the tape to allow maximum airflow and wait for the camera to warm up and any condensation to evaporate.
If the condensation warning had come on and your camera hasn't experienced a sudden change of temperature, this could indicate a possible fault. I'm afraid this is not something you would be able to fix yourself.
Matt
SOURCE: Please wait -Condensation operation Paused
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
