That clicking sound is the safety relay not clicking in to protect the TV from frying out. The problem is most likely the power board.
Testimonial: "Is there a part on the power board I can test or replace? I've replaced the bridge rectifier on it, and I still have the same problem."
SOURCE: LG 32fz4d-ua partially powers blank
I had the same problem. It was the "Flyback transformer" after they first replaced the power supply.
SOURCE: when its turned on it clicks on and off over and
The logic board is sensing an overload condition and is stopping the power board from producing high DC voltage. The logic board will try 3 times to boot-up the power supply and when the same condition appears it shuts the power supply down. DC high voltage output is being held down and only 5volts stand-by is active. The power board needs to be tested and logic controls also. If you have some test equipment and some electronics background I can show you how to fix this problem....
Get back too me about this when you can....
[email protected]
SOURCE: my lg plasma 50pk750 turns
I think i could be a power supply issue... If you have the courage to open the back cover of your tv, and you do "NOT" see any bad (bulging ) capacitors on the power supply board, then it could be the voltage regulator. Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at [email protected] if you have any question.and watch the video:
http://www.youtube.com/watch?v=I9wF0OLyV0k&feature=youtu.be
http://www.youtube.com/watch?v=vHrv5XaDULI&feature=youtu.be
SOURCE: I have a LG Plasma 50PK750 that when you turn it on and goes right back off.
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at [email protected] if you have any question.and watch the video:
SOURCE: when i inplug my lg 50pk750 plasma to power sorce
This issue is a
http://www.viewbix.com/v/LG-Repair-KIT-now-available-on-Ebay/8ec4bea5-1d91-4d23-8180-7e5214e6c8f6
warranty, and now you're hearing a series of clicks. ... If you have the
bad (bulging ) capacitors on the power supply, then it could be the voltage
regulator. After weeks of fighting
[email protected] if you have any questions.and watch the video: part 1
& 2
Repair kit on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200849231403
Youtube
video PART 1 & 2
This issue is a
