My Blackberry Pearl 8110 is showing an error code of "jvm error 545" and my computer will not read the device to fix it. How do I get my computer to read the phone and how do I fix the error code?
To correct this issue try this method
You need to reflash the OS on the phone you should take the
battery out first then connect it via the usb cable to the laptop/pc
you are using then open the blackberry desktop manager,click on the
apploader, then install the OS.
pls not that when u click on the apploader the pin should be
PIN:UNKNOWN you make need to do this like 4x before the pc sees the
pin:unknown but it will work once it see the pin:unknown you can
re-insert the battery and continue with reflashing the phone
