Ref: KEBC107KSS04
After lighting threw some circuit breakers, we could reset everything except the oven's circuit breaker. Does the oven have its own reset button? What to do?
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
If your oven won't heat at all, the most likely problem is a blown fuse or a burnt out element. Assuming you're not attempting to repair an antique, your oven will have a clock. If it has also stopped working, it's safe to assume the oven is not getting electricity. Check your circuit breaker box and reset the breaker if necessary and see if this fixes the problem. If not, cut power to the oven at the breaker box before going any further. Note that your oven runs on 220 volts. There should be a double switch on the circuit breaker board controlling power to it. If not, there will be two single switches that need to be tripped to cut power to the oven. Even if you didn't find a blown circuit breaker, the problem could still be a blown fuse. Some older ovens have their own set of fuses located under the range top, in the back of the oven space, or behind the oven. Inspect the fuses and replace any that have blown with one of the same amperage. Your oven might also have a circuit breaker with a reset button on the control console or on top of the oven that needs to be reset. If you are still confounded, pull the oven away from the wall. If it is a range/oven combo, make sure it is plugged securely into the wall. If it is a stand-alone oven, inspect the wiring in the junction box to make sure everything is tightly connected and the wiring doesn't show any signs of damage.
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
