I understand that the burners and broiler are working in your Frigidaire range, model# PLGFZ390ECB, but the bake element does not work. I also see that you have replaced the igniter and it is still not working. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your oven will not come on. Hope this is helpful.
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
