Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
make sure the gps have a full view of the sky. leave it in aquiring mode and let it sit there. My Emap took up to 35 mins once to reaquire the sats and get the updated info needed for position info.
if the unit has been off for a long time or moved a long distance from where it was last turned on, it can take a while for it to come back up.
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
