SOURCE: transmission slipping,dies in drive
Hi there.Hope this can help.On the top of the transmission there's a black electrical plug that the shift linkage goes in..It sounds like the range sensor is out of adjustment..If you try going from reverse to like first or second does it still stall.You may have to get it adjusted.Does the selector in the car where it say P R N D 2 1 Line up with its indicator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: Transmission will only go into reverse
I would check the linkage and if it is all connected and working then the problem is internal. A pump can go and leave no shavings or metal flakes in the pan.
To check the linkage put the truck on ramps, support it with jackstands crawl under the truck while someone sits in the drivers seat with the parking break on. Watch the linkage levers on the transmission as the person in the truck moves the shift lever (while firmly mashing the breaks) also listen for a distinct "clicking" sound in the transmission as it moves through the gears. Again if the linkage is okay and it sounds like things are moving with the shift leaver then the problem is most likely a worn pump.
